stripped bolts
Old May 7, 2008 | 09:57 PM
racin66coupe's Avatar
racin66coupe
Default stripped bolts
when i went ot takt of the fenders to finish stripping the sheetmetal of the front end, i found 2!! stripped bolts! im guessing its something the PO did[&:]is the only way ot get it out is drilling the tapping a new hole? its the one going into the rocker and of of the bumper brackets
Old May 8, 2008 | 11:58 AM
7tMach's Avatar
7tMach
Default RE: stripped bolts
If you have a welder, whether it is stick or mig, do this. If you can see the remaining part of the bolt, take a nut, center it where you can see the stud and weld the stud to the nut. The heat will help with removal. Done right, you should be able to take a wrench to it and remove it. It the nut comes off, just weld it again. Most people are afraid to do this and do not get a good penetration to the remaining part of the stud. Remember: Torch angle definnes direction of penetration. So if you are pointed exactly to the stud, that is where the penetration will be. We do this ALL the time. FEAR NOT!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
wraith777
Sep 28, 2015 10:49 AM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
