Fuel Reading
Old May 9, 2008 | 09:48 AM
fast65's Avatar
fast65
Default Fuel Reading
Does anybody else here have a REALLY bad reading on their gas gauge, I can never get it to be accurate. The first half of the tank it reads somewhat accurately, but once it gets past a half of a tank it just takes a dive and I usually end up driving on "E" for a week or so. Has anybody else had this problem? I've replaced the gauge and the sending unit, what else could be the problem? Thanks in advance.
Old May 9, 2008 | 12:09 PM
snorulz's Avatar
snorulz
Default RE: Fuel Reading
mine is off quite a bit, got much worse when i put in a new tank and sending unit. Mine just drops off fast through the entire range, when it says 1/4 tank i have used less than half. Empty now means i have used just a tad more than half. It is very annoying. I would love to know what the problem is also.
Old May 9, 2008 | 04:31 PM
kalli's Avatar
kalli
mine works perfectly fine, if it says empty i can fit about 55 litres into the tank (seems correct to me)
usually a bad reading is a sign of bad ground, or bad connectors between the sending unit and the gauge
Old May 9, 2008 | 08:08 PM
67 evil eleanor's Avatar
67 evil eleanor
Yep, clean the terminal and squeeze it together some. It may help.
StalkerGT
Sep 25, 2015 02:41 PM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
