Leaf springs
Old May 9, 2008 | 12:55 PM
paddy187's Avatar
paddy187
Default Leaf springs
Ok folks just got my new leaf springs and there are not completely identical one is slightly higher by 7-10mm, I half remember that this is attentional, so which side does the higher one go drivers or passengers?
Cheers
Paddy
Old May 9, 2008 | 02:53 PM
baddog671's Avatar
baddog671
Default RE: Leaf springs
I'd put the taller one on the driver's side...
Old May 9, 2008 | 05:56 PM
groho's Avatar
groho
If you haven't done so already, turn them upside down on the pavement, and put your weight on them to break the dried paint loose. Sometimes that will make a difference. And yes, higher one on drivers side.
Old May 10, 2008 | 01:26 AM
paddy187's Avatar
paddy187
Cheer lads that was my plan, first have to get it through it's yearly APK which is road worthyness check
Old May 10, 2008 | 10:08 AM
crunchyskippy's Avatar
crunchyskippy
You could consider placing the higher arch on the passenger side to counter the effects of drive-line torque (under hard acceleration). But I have to admit I wasn't aware the leaf arches were different heights, so I don't know which side is the "conventional" side. Good luck with your decision!
Old May 10, 2008 | 03:01 PM
baddog671's Avatar
baddog671
I believe it is to compensate the driver's weight, but that's just what I've heard. Mine were identical as much as I could tell...
Old May 14, 2008 | 01:11 PM
68pony5's Avatar
68pony5
Dam. I just replaced my leaf springs and really didn't pay attention or notice a height difference. I that a big deal?? The car rides nice now with no bottoming out and no bounce. The ride height looks great too?
Shall I worry about it if they are on the wrong side?
68pony5
Old May 14, 2008 | 01:16 PM
baddog671's Avatar
baddog671
Dont worry about it unless you can actually see it...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
