High Octane additives??
Old May 10, 2008 | 09:45 AM
pasco6363's Avatar
pasco6363
Default High Octane additives??
I am an new member to this forum. I have a '66 Coupe that ran out of gas after the sending unit failed. I got a gallon of gas from road side assistance that wouldn't take me too far soI was only able to put 91 octane in the tank so I shouldn't have filled it up I guess. Anyhow it's knocking now and I was wondering if there is a good additive that I can put into this tank only. I usually use Ultra 94 from Sunoco and it runs fine.
The car has a high performance 4-barrell 8 cylinder in it now.
Any thoughts?
Thanks!
Old May 10, 2008 | 10:19 AM
Daze's Avatar
Daze
Default RE: High Octane additives??
If you only put a gallon of the 91 in than I would fill it with the full octane stuff you normally run. If that doesn't do it any octane boost addtive should work, just make sure you add it to a full tank of gas. You must have a high compression motor or lots of advance for it to be nocking with 91??? BTW welcome to the forum
Old May 10, 2008 | 11:03 AM
pasco6363's Avatar
pasco6363
Thanks for the advice. One more thing for today. I only drive this once a week or so and I got in last night and the battery was dead. The glove compartment was left open (light inside) so maybe that's what drained the battery over a few days. Anyhow, it boosted fine and I drove it for 20 minutes or so. When I put it in my garage I was able to turned it on and off a few times no problem but it was dead again this morning. Any ideas?
Old May 10, 2008 | 11:10 AM
Daze's Avatar
Daze
running a battery dead will literly kill it. Either you have a drain some where or you need a new battery. I would put a one amp trickle charger on the battery, should take a couple of days to charge up. Then see if it holds a charge. if not than have the battery tested.
CS2007
Jun 25, 2019 09:45 PM
b8checker
Oct 8, 2015 12:55 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
b8checker
Sep 30, 2015 07:11 AM
Drastang
Sep 30, 2015 03:48 AM
