289 bored .40
Old May 13, 2008 | 10:21 PM
jonm1a1's Avatar
jonm1a1
Default 289 bored .40
I am in the market of buying a 289 that is already machined burnt beaded and all that plus boreded .40 just ready to be put back together. My question is that i had that same engine bored .40 over in my car and it would always over heat and then i put a hole in the cylender wall. I did every thing to fix the over heating issue. will this new 289 over heat since it is bored .40 over also? The engine block was only 300
Old May 13, 2008 | 10:23 PM
ky's Avatar
ky
America ftw
Default RE: 289 bored .40
i wouldnt risk it imo.
i found out my block was already .30 over and everyone at my work (check sig) said it wasnt worth it. if its a stock engine, you can get away with it. but if its a mild street engine then i say no.
Old May 13, 2008 | 11:07 PM
Iskwezm's Avatar
Iskwezm
I had a .060 289 and it was fine.Lasted about 15 years and a whole lotta nitrous
Old May 13, 2008 | 11:16 PM
67mustang302's Avatar
67mustang302
It's hit and miss. Factory core shift is sometimes bad, some engines will go .060 without problems, others have problems at .040. Mine's at .040 and no issues, but that doesn't mean the next one at .040 will be fine either.
Old May 13, 2008 | 11:51 PM
ky's Avatar
ky
America ftw
exactly, its not worth the risk imo.
i bought my standard bore block for $50. plus it came with a set stock heads, a fan, and extra valve train ****. but of course i got all my machine work free cause i work at the machine shop lol.
Old May 14, 2008 | 05:03 AM
kalli's Avatar
kalli
ORIGINAL: true66gt
I'd say working in a machine shop is the reason that you got the block for 50$ in the first place :-)
I'd love to be able to get a block here. I'd build it up ever so slowly and when finished dump into the car. time is no issue, sourcing a block is impossible here
Old May 14, 2008 | 07:37 AM
muggsy's Avatar
muggsy
Depending how bad you want a 289, I would call this guy...he can be expensive for a block seeing you can get a roller 302 just about anywhere..
http://www.allclassicmustang.com/
He can be a bit expensive, but he's got good service etc and don't go by his online inventory, he probably has more in stock than it says...
uberstang1
Dec 7, 2017 07:10 AM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
GTJIM
Sep 23, 2015 09:59 AM
JayGee
Sep 15, 2015 12:41 PM
ryland
Sep 13, 2015 12:35 PM
