Floor pans
Old May 14, 2008 | 07:26 PM
Shawnb23's Avatar
Shawnb23
Default Floor pans
Well I finnaly got around to buying myself a welder for my garage...I bought a miller 180. My question is how has everyone gone about securing the pan's to the frame rails to make them nice and snug befor welding? I really don't believe sheet metal screw's are the best way to go about securing them?
Old May 14, 2008 | 07:29 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
Default RE: Floor pans
what you can get to, use welding C clamps, and i also used tiny screws, then removed them and welded the holes,...that is about the only way to keep them tight,..that i know of
Old May 14, 2008 | 08:01 PM
Tony R's Avatar
Tony R
I ran a bolt through the hole that was in the floor pan and that lined up with the hole that was in the frame rail. Use some fender washers so that you done warp your pan too bad.
Old May 14, 2008 | 10:57 PM
zmetalmilitia's Avatar
zmetalmilitia
Some places the only option is to use small screws, where c-clamps won't reach. After welding the pan in, take the screws out and plug weld the holes.
Old May 15, 2008 | 05:05 PM
ky's Avatar
ky
America ftw
i didnt need any types of screws or bolts. i just took the time so they fit almost perfectly.
Old May 15, 2008 | 05:33 PM
Shawnb23's Avatar
Shawnb23
Wow those look good.. well I think screws are going to be my only option.. the toe boards won't fit in snug without chopping out more of the tranny tunnel which I don't wanna do.. and I don't wanna chop the pan to much:S The long floor pans I purchased also don't seem like they fit properly on the front frame rail without some persuasion.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
