Removing lifters???
Old May 15, 2008 | 03:32 PM
nails1856's Avatar
nails1856
Default Removing lifters???
How do I remove the lifters from a '65 200 6 cyl?
Thanks,
E
Old May 15, 2008 | 04:56 PM
ky's Avatar
ky
America ftw
Default RE: Removing lifters???
with a magnet and some needlenose vicegrips.
Old May 15, 2008 | 05:24 PM
Sean W.'s Avatar
Sean W.
finger nail.. the literaly pull stright out, no tricks.. they slide in, slide out. just ogtta grab em' and lift
Old May 15, 2008 | 05:33 PM
boogerschnot's Avatar
boogerschnot
you can turn the crank too to pick up the ones that are down in the block..
Old May 15, 2008 | 08:00 PM
Starfury's Avatar
Starfury
On an old engine, the lifters may be slightly mushroomed at the bottom, making removal a little more complicated. I ran into this a couple years ago when the shop I worked for was rebuilding a 200.
Old May 15, 2008 | 08:10 PM
ky's Avatar
ky
America ftw
another trick is to leave em in till last and spin the block over and use a hammer and punch (im not sure about the 6 but i know you can on the 8) but be careful of scratching or dinging the lifter bores.
Old May 16, 2008 | 04:33 AM
nails1856's Avatar
nails1856
Thanks. Got them out. Kinda hooked by the top with a bent awl, then worked them out with a pair of needle nose pliers. Came this far ...may as well replace them all.
Stupid question: are they supposed to compress? One come apart and I noticed a spring inside. Tried to compress another and it didn't budge. Just curious how they worked.
Thanks again,
E
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
wawagner82
Sep 13, 2015 09:02 AM
