what length pushrods?
Old May 15, 2008 | 06:33 PM
Sean W.'s Avatar
Sean W.
Default what length pushrods?
what length pushrods do i want to get for my 68' 302?
Old May 15, 2008 | 07:58 PM
Starfury's Avatar
Starfury
Default RE: what length pushrods?
If any machine workor swapping of heads has been done, I'd get an adjustable pushrod length checker. That way there's no question.
Old May 15, 2008 | 08:14 PM
ky's Avatar
ky
America ftw
depends on your setup. cam, heads, rockers, vavles. etc.
get one of these:
then adjust to correct lash, then measure with a large pair of calipers.
Old May 15, 2008 | 08:18 PM
Sean W.'s Avatar
Sean W.
how much would one of those cost?
and.. what would happen if i got the wrong size? to long, to short?
Old May 15, 2008 | 08:21 PM
ky's Avatar
ky
America ftw
could be as less as $4
Old May 15, 2008 | 08:22 PM
ky's Avatar
ky
America ftw
or $37 for a WAY better set
EDIT: SBF pushrod length is around 6.5 i think so make sure its +/- 1" or so off of a 6.5" pushrod.
found em for your app.:
http://www.jegs.com/p/Crane/747136/10002/-1
Old May 15, 2008 | 08:36 PM
SalikDDD's Avatar
SalikDDD
should be stock standard size. that's what i threw back in mine with P heads on em, now that i'm swapping to the edelbrocks with true roller rockers i'm using em again since that's what they call for.
Old May 15, 2008 | 08:44 PM
Starfury's Avatar
Starfury
The Comp Cams tool is $20, iirc, and you don't have to measure anything. It's set up like a dial indicator so you can read the marks on the tool and compare to the instructions to find the length.
69Volunteer
Sep 30, 2015 10:39 AM
junior04
Sep 28, 2015 10:53 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
S'PortMustang69
Aug 30, 2015 08:27 PM
Hillbilly1968
Aug 19, 2015 12:03 PM
