monte carlo bar
Old Sep 6, 2007 | 05:41 PM
eep4life's Avatar
eep4life
Default monte carlo bar
what does the monte carlo bar do... i think thats what its called... is it a good investment
Old Sep 6, 2007 | 05:48 PM
Starfury's Avatar
Starfury
Default RE: monte carlo bar
Yes, it is. It bolts in between your shock towers to keep them from flexing inward during cornering. Keeps the car flatter in corners to improve handling. It kinda feels like adding a bigger sway bar, without the reduced ride quality.
However, you should think about an export brace first. This is a one-piece shock tower brace to replace your flimsy factory two-piece setup. It not only ties the shock towers together, it also ties them to firewall. If you had to pick between the two, the export brace would be more important. But they function very well together and are both fairly cheap, so for $70 or so you can drastically improve your handling without modifying your suspension.
Old Sep 6, 2007 | 05:51 PM
blueovalboy7's Avatar
blueovalboy7
They're fairly cheap too, between like 20 and 50 bucks is what I've seen.
Old Sep 6, 2007 | 06:11 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
If you go to install the export brace & find the bolts dont match up. Jack the car up and let the front wheels hang off the ground over nite, The chassis should "relax" enough to fit it in then. I actually had to resort to using a bottle jack to help push the shock towers appart, before mine would drop in. That in itself should tell you how much they, both , do help stiffen the chassis.
The front alignment will need to be done again then too.
Old Sep 6, 2007 | 07:05 PM
RSRXION's Avatar
RSRXION
What year Mustang are you working on ? There are bars available for all years but the store offerings for the 71-73 don't fit. I made my own for my 73 and I saved the pattern if you need one. If your car is a 71-73 with air, it's going to be darned near impossible to make one fit. JMHO, Dean
Old Sep 6, 2007 | 07:35 PM
Wayne67vert's Avatar
Wayne67vert
I put both on my 'vert. I couldn't believe how they took all the cowl shake away. The front fenders and hoodare rock solid now. I would recommend everyone use them.
Wayne
Old Sep 6, 2007 | 08:40 PM
eep4life's Avatar
eep4life
alright sounds good... i deff. going to get them, oh and im working on a 69.... ill see about getting them soon due to the fact that i just finished my brake conversion and new suspension kit so i can get the alignment done all together... thanks guys
Old Sep 6, 2007 | 09:13 PM
Galactusz's Avatar
Galactusz
I love the Monte Carlo bar, I also installed the export brace, they go hand in hand.
Old Sep 6, 2007 | 10:46 PM
knuckless's Avatar
knuckless
would you recomend the straight monte carlo bar or the curved
Old Sep 6, 2007 | 10:55 PM
Galactusz's Avatar
Galactusz
I hear the straight one is stronger (especially on impact)...but the curved is more asthetically pleasing and it's also better if you plan to make some mods like EFI, etc...
You can go either chrome or all black, I went all black.
