not enough fuel
Old May 17, 2008 | 03:57 PM
19stang66's Avatar
19stang66
Default RE: not enough fuel
It came with the Pertronix ignition already installed, so no points for me. What about a stock coil? But then I'd have to regap my plugs back down to .03X, they are at .040 right now. And I don't have the tools with me for that.
Old May 17, 2008 | 04:12 PM
ky's Avatar
ky
America ftw
are u on an iphone or laptop? cause how are you posting in a parking lot????
sorry i dont know how to solve ur problem
Old May 17, 2008 | 04:16 PM
19stang66's Avatar
19stang66
blackberry I'm gonna go check the timing quick and check some plugs, hopefully they aren't fouled. Probably gonna buy a new fuel pump too.
Old May 17, 2008 | 04:58 PM
RGMotorsports's Avatar
RGMotorsports
do you have the petronix module, or just the coil. I was referring to a petronix ignition module could be fouled up, it happened to a 68 302 i replaced for a guy who insisted on a petronix over the crane unit i reccomended, the petronix failed within a month.
Old May 17, 2008 | 05:33 PM
19stang66's Avatar
19stang66
both. The module looks pretty clean to me. I'm replacing the fuel pump as we speak but I am having troubles putting the new one back in. Ugh nothing ever goes back together right on this damn engine.
Old May 17, 2008 | 07:13 PM
19stang66's Avatar
19stang66
Just put in the new fuel pump and that didn't help at all. I checked the jets to see if they were clogged and they were fine. Could it be bad gas? I put in a new tank the day I parked it. I can't drain the tank that easily since there isn't a plug. Is there an additive I use to help burn up this tank of gas? Seafoam??
Old May 18, 2008 | 11:25 PM
Aussie66Fastback's Avatar
Aussie66Fastback
did you get a result yet?
this might sound stupid, but are you sure its not too much fuel...a stuck float in the carb?
Old May 18, 2008 | 11:42 PM
mustanglover66's Avatar
mustanglover66
Try looking at the fuelline from the tank and see if its dented or kinked any where.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
