Door Glass Removal
Old May 20, 2008 | 09:33 AM
vernlee's Avatar
vernlee
Default Door Glass Removal
Hi, is there anyplace on the net. that gives me instructions on how to remove the door glass and all the mechinisms ? I'm putting on new doors on my 66 coupe and hate to just start tearing it apart without knowing what I'm doing.
Vern
Old May 20, 2008 | 10:25 AM
Nick.Simonds's Avatar
Nick.Simonds
Default RE: Door Glass Removal
Not sure if there it on the net. I would defiantly buy a shop manual though, they are like the Bible for the Mustang.
Old May 20, 2008 | 10:31 AM
66JameStang's Avatar
66JameStang
+1 on the shop manual,
and WELCOME!!!!
From what I can tell the glass is connect to a much larger piece inside the door, even after removing the felt I could not get the glass to come through the top of the door. I ended leaving the glass in because I could not get it to detach, you may have to have a glass shop do it because it appears to be attached with adhessive. There is also a bumper in the bottom of the door that is a pain to remove.... good luck!
Old May 20, 2008 | 10:47 AM
pjlietz's Avatar
pjlietz
I've pulled mine twice and it wasn't that hard if I remember. I can't really remember how I did it though, lol.... It was a long time ago. I couldn't find anything online but I'll look through my books and see if I can find a few pointers for you.
Old May 21, 2008 | 10:48 AM
vernlee's Avatar
vernlee
thanks for the responses, I dismantled the drivers door,what a pain,I will definitly put the new
door back together before I take the passengers side apart so I have a pattern to go by.
If you come up with any instructions let me know,I will look into getting a shop manual.
Vern
Old May 21, 2008 | 11:05 AM
zmetalmilitia's Avatar
zmetalmilitia
I took my door internals apart, bagged everything. Now the car is in the body shop getting work done and paint. I asked the guy how hard it was to reassemble the internals and he said it wasn't hard. It isn't if you've done it once or twice. He is gong to do it for meas I don't want to screw anything up. I know I could do it, I just don't want to mess with it. It would probably take me all day where he would spend an hour or two on them and be finished. And they would work correctly the first time. Good plan to reassemble the one door as you take the other apart. That will give you a reference.
cr620
Oct 3, 2022 10:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 25, 2015 06:58 PM
