carb flooding after engine is off
Old May 22, 2008 | 09:52 PM
ddg1025's Avatar
ddg1025
Default carb flooding after engine is off
what would cause the throttle bodys in the carb to fill up with gas after the engine is shut off
thanks with any hints
Old May 22, 2008 | 10:17 PM
67mustang302's Avatar
67mustang302
Default RE: carb flooding after engine is off
Electric fuel pump? What's your fuel pressure?
Old May 22, 2008 | 10:21 PM
ddg1025's Avatar
ddg1025
yes it does have an electric pump it is one of those inline fuel pumps any ideas on how to stop it
Old May 22, 2008 | 10:28 PM
67mustang302
How is it wired, and what's the pressure? It should be wired to a switched circuit so that it stops pumping when the engine is turned off. Does it require a return line to the tank, and if so does it have one?
Old May 22, 2008 | 10:47 PM
ddg1025's Avatar
ddg1025
it just has an on-off switch that i turn off when the engine is shut off. i dont think it requires a return line but im not sure. and it doesnt have a return line. its on this old F100 truck that was left by the last resident of my house so i dont know how it was built up
Old May 22, 2008 | 11:00 PM
67mustang302
Well, first hook the pump switch wiring up to a switched circuit of the correct voltage(I'm assuming it's 12v). What's the pressure at?
Old May 22, 2008 | 11:21 PM
ddg1025's Avatar
ddg1025
its already hooked up to a switched circuit at the right voltage but i am not sure of the pressure how much pressure does the carb need its a 2 barrel 351 i believe
Old May 22, 2008 | 11:31 PM
67mustang302
Most carbs only need about 6.5psi give or take. If the pressure is too high it will overload the needle and seat pressure, and flood the bowl.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
wawagner82
Sep 13, 2015 09:02 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
