coolant leak
Old May 23, 2008 | 07:32 AM
built67's Avatar
built67
Default coolant leak
i just took off my old stock intake manifold and 2bbl carb and put on a dual plane wiand x-celerator intake manifold with a edelbrock 650 cfm 4bbl carb... it started up and ran strong but when i put coolant in it and it hit a certain level it started leaking from one of the heads...could this be because i might have not put enough silicone around the intake gaskets?
Old May 23, 2008 | 08:15 AM
Starfury's Avatar
Starfury
Default RE: coolant leak
I'd guess that maybe you put too much on, or let it dry too long before torqueing the intake, or maybe even overtorqued the intake. You only need a very thin smear of silicone around thecoolantports on the intake gasket. Lay down the front and rear silicone beads first, then smear some silicone around the coolant ports on the gaskets, than immediately drop them into place and torque the intake down to about 20ft-lbs.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
