Alignment
Old May 24, 2008 | 02:25 AM
paddy187's Avatar
paddy187
Default Alignment
This is for my DD but I took it be aligned and I have to different brands of tyres on the front, the guy said you we can't align cars with different name tyres, you need new ones. At this point I left as to me the alignment can be set with 2 different name tyres it may differ slightly with the different name tyres, (possible different tread depths)but not significantly. As the alignment to me is all suspension geometry, amI correct here?
Old May 24, 2008 | 10:45 AM
Daze's Avatar
Daze
Default RE: Alignment
he is full of it. alignment is based off the spindle angles, and the tires have nothing to do with it.
Old May 24, 2008 | 11:01 AM
titan aresta's Avatar
titan aresta
I'm sure he can physically do the alignment, but he might have a policy of not doing such work on a car with two different tires on the front. It is also most accurate to do an alignment on new tires instead of used ones.
Having two different tires on the front is... uh.. not smart.
Old May 24, 2008 | 11:50 AM
65Coupester's Avatar
65Coupester
I did front end alignments way back in '76. Obviously tires have improved, however, a difference in the front tires can cause to car to pull or drift a bit.
The guy just wanted to guarantee his work.
As Titan said, he could align the car and just issue a disclaimer.
Old May 24, 2008 | 11:55 AM
1slow67's Avatar
1slow67
ROTM Moderator
Sounds like he was just trying to get some more money.
Old May 24, 2008 | 11:56 AM
paddy187's Avatar
paddy187
cheers guys as he sell tyres and a seriously doubt it's about quality of his work more about trying to get more cash.
Old May 24, 2008 | 04:27 PM
kalli's Avatar
kalli
Hi Paddy,
In Germany both wheels on one axle have to be same size and make and model. otherwise you won't pass NCT/MOT or whatever the test is called.
In Ireland they only have to be same size
I'm not a fan of different tires in the front, sometimes the car pulls to the side then when rolling resistances are different.
Or when braking. So maybe the mechanic just backed his ***.
physically he could have done it, but he don't want you coming back and complain ...
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
