Shelby Drop
Old May 26, 2008 | 11:23 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default Shelby Drop
Anybody have some tips for me before I start the Shelby drop? I am getting the template from a local mustang owner at around 12:30. I do have a spring compressor, but I really don't like it only because it has slipped on me 2 times.
Old May 26, 2008 | 12:29 PM
Daze's Avatar
Daze
Default RE: Shelby Drop
check out my web page on the subject.
http://home.bresnan.net/%7Edazed/drop
Old May 26, 2008 | 02:02 PM
paddy187's Avatar
paddy187
I am a bit worried about using my claw type one to remove my coil springs which means I am procrastinating.
Old May 26, 2008 | 02:53 PM
ky's Avatar
ky
America ftw
just drill the holes 1" down exactly. nothing hard.
Old May 26, 2008 | 04:00 PM
Daze's Avatar
Daze
ORIGINAL: true66gt
Only true if he has a 67-70. If he has a 64.5-66 than it is 1" down 1/8" back. If it were done with just 1" down from the original holes you will mess up the UCA's location in relation to the LCA which will screw up the ability to set caster correctly.
Old May 26, 2008 | 04:03 PM
ky's Avatar
ky
America ftw
he has a 67.
i have a 66 and went down 1" and back 1/8"
Old May 26, 2008 | 04:47 PM
1slow67's Avatar
1slow67
ROTM Moderator
ORIGINAL: paddy187
I got advise from the guy and he said duck tape the claws in place so they don't slip.
Old May 26, 2008 | 05:44 PM
Aussie66Fastback's Avatar
Aussie66Fastback
I did mine a couple of months ago. here's my $0.02
make sure you have nice sharp drill bits and start small then build up size.
are your UCAs in good condition? Now is a good time to do top ball joint and refurbish the inner pivot as well.
dont forget your wheel alignment specs. whatever shims you have in place now, make sure they go back the same way. that will leave it driveable to get you to a wheel alignment shop
good luck.
Old May 26, 2008 | 06:02 PM
1slow67's Avatar
1slow67
ROTM Moderator
I just got the car aligned 2 months ago. 67s don't have shims I think. I think all of my suspension is in good shape from when I took off the wheel last week. I might be getting some new rims next week depending on how high they get on Ebay.
Old May 26, 2008 | 10:41 PM
juansp67's Avatar
juansp67
ORIGINAL: BA Mustang
I have never heard about this shelby drop. Y dont u just get the 1" drop coils (rt at 620lbs) that would save you the hassle on doing this modification right or are you doing this to use the original coil height?
ORIGINALAZE
If i did this conversion to my 68 mustang their is no modification needed but to drill the holes 1" down from the original holes and just bolt them back on?
