Shelby Drop
Old May 26, 2008 | 11:27 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Shelby Drop
ORIGINAL: juansp67
ORIGINAL: BA Mustang
Anybody have some tips for me before I start the Shelby drop? I am getting the template from a local mustang owner at around 12:30. I do have a spring compressor, but I really don't like it only because it has slipped on me 2 times.
I have never heard about this shelby drop. Y dont u just get the 1" drop coils (rt at 620lbs) that would save you the hassle on doing this modification right or are you doing this to use the original coil height?
ORIGINALAZE
Only true if he has a 67-70. If he has a 64.5-66 than it is 1" down 1/8" back. If it were done with just 1" down from the original holes you will mess up the UCA's location in relation to the LCA which will screw up the ability to set caster correctly.
If i did this conversion to my 68 mustang their is no modification needed but to drill the holes 1" down from the original holes and just bolt them back on?
Drop Coils will make the ride horrible over bumps. Due to them not moving as much as the old springs. You only need the template to drill the holes and bolt them back on. No modification is needed for this. Also the shelby drop lowers the car, increases handling, and makes the steering more reactive. Go to Daze's site and read about it.
Jamison's Avatar
Jamison
[quote]
Old May 27, 2008 | 08:56 AM
Daze's Avatar
Daze
ORIGINAL: juansp67
You don't do the UCA drop for the purpose of lowering the car. the drop is done to improve the camber curve and decrease understeer.
ORIGINAL: juansp67
It is 1" down, BUT it is 1" down perpindicular to a line that bisects the existing holes. As was already mentioned there is lots of good info on my web page linked earlier in this thread
Old May 27, 2008 | 10:22 AM
kalli's Avatar
kalli
hi lads,
friend of mine has a 68fastback. His ride is a bit nosehappy, so the front seems to sit a bit higher than the back, which looks awful.
Will the shelby drop be the thing he needs doing? as we were discussing the option of cutting the spring already (which I hate)
kalli
Old May 27, 2008 | 12:12 PM
chromedog's Avatar
chromedog
the shelby drop will NOT lower the car 1" ...at very most you will lower it 3/8 inch. what you are doing is changing the pivot of the upper control arm for camber gain.and while we are on the subject, (question for dazecars) can the holes on a 65-66 be drilled 1" down, and, say 3/16 back? im asking this because my 65 still doesnt get the caster i want with the holes drilled 1/8 inch back...if i adjust for caster, i cant get the camber right...
Old May 27, 2008 | 12:40 PM
paddy187's Avatar
paddy187
I have thought of a plan for my coil removal I will lash my coil spring compressor to the coil with strong fishing line with a high breaking strain and It will slow me down but hopefull keep me safe. I don't want to have happern to daze happen to me and I have not the skills to fab his style one.
Old May 27, 2008 | 01:23 PM
Daze's Avatar
Daze
ORIGINAL: chromedog
In most cases 3/8" is the amount of ride height drop that you get from relocating the UCA by 1", but depending on coil stiffness the drop will result in 1/4" to 5/8" drop with the stiffer the springs the less ride height change and the softer the springs the more ride height change. As far as drilling the holes further back you can easily do it on a 67+ mustang even as much as 1/8" but on a 64.5-66 you run in to clearience issues with the inner ribbing of the shock tower support and the natural bend of the shock tower. The picture below shows the rear hole on the drivers side. Removing the support ribbing is not an issue, but as the white line shows, the bend in the tower is close and may cause clearence issues with the nut. It can be done but I would not go more than a 1/16". The best way to get that extra caster is to rebuild the UCA and offset the shafts.
Bokeo
Oct 10, 2015 08:28 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
ChampInSD
Oct 2, 2015 04:55 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
mungodrums
Sep 28, 2015 10:54 PM
