Why was it leaking?
Old May 27, 2008 | 12:56 PM
boogerschnot's Avatar
boogerschnot
Default Why was it leaking?
My oil filter started leaking this weekend. at first I thought it was my pan gasket, but upon further inspection I found that i was leaking from the filter rubber gasket.. Thats strange, I allways heard that you only put the filter on hand tight "snug" right? So I changed the filter, put a new motorcraft one on thinking that it was just the gasket, but this one leaked just as much.. Which was a steady drip.. So I grabbed my handy filter wrench and put another couple of half turns on the thing and it finally sealed up, but its now on there really tight..
Any one else have this problem? My block surface seemed in good shape, no nicks or dings to make it leak..
Old May 27, 2008 | 01:01 PM
Stepman's Avatar
Stepman
Default RE: Why was it leaking?
Well, you should run it on til it touches the block, then give it another 3/4 to a full turn.
Old May 27, 2008 | 01:55 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
when i do an oil change on the 67, i lube up the rubber ring around the new filter with the old oil, clean the block surface, then put it on there nice and snug.
Old May 27, 2008 | 02:00 PM
imnotmy77stang's Avatar
imnotmy77stang
im thinking your just not very stong?[&:]
or maybe your leaving the old rubber on the block?!?! sometimes they come off the filter and stick to the motor - always gotta make sure its off before installing the new one.
+1000000000.3 for lubing the rubber before reinstalling the new filter (i use new oil, but it doesnt really matter). i also fill the filter with oil before installing. if you fill it up once it will absorb most of the oil and when you **** it to screw onto the side of the motor you shouldnt really spill any. this helps prevent any moments of oil starvation when you start the car for the first time after a change.
Old May 27, 2008 | 02:29 PM
boogerschnot
ORIGINAL: imnotmy77stang
Well thanks[:'(]!! LOL..
I did put some oil on the ring as allways, It just would not seal up by cranking on it with my hand.. oh, well If i have to crank on it from now on I will,, as long as it dont leak like that any more..
Old May 27, 2008 | 04:09 PM
crunchyskippy's Avatar
crunchyskippy
That's the first thing I thought of, too. Ask me how I know that two rubber gaskets are not better than one...
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
