help with 65 clutch
Old Jun 9, 2008 | 12:31 AM
WD0AFQ's Avatar
WD0AFQ
Default RE: help with 65 clutch
The answers have been posted. It has to be one of them. The clutch lever has either slipped off the ball, happened to me. Or your spring is off the clutch pedal. And/or your shifter linkage is not set right. Has to be one or a combination of these things.
Hope that helps, I have no photos to post.
Dan
Old Jun 9, 2008 | 06:31 AM
tyler72's Avatar
tyler72
If your pedal falls to the floor, then you dont have the linkage hooked up to the release arm correctly. Even if the spring on the linkage or under the dash is off, the springs in the pressure plate will push the pedal back up if the linkage is on. As far as it being in reverse when the shifter is in neutral, you must have a 3 speed and gotten the linkages out of adjustment or the rods on backwards. Did you mess with the adjusters any, or did you just take them off when the transmission was removed?
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
