Flyweigh weight....
Old Jun 6, 2008 | 03:09 PM
baddog671's Avatar
baddog671
Default Flyweigh weight....
So I have a flywheel laying around that is in good condition and the correct size for my 351W. Its 164tooth and 14". Did all of these flywheels come with the correct 28oz. weight, or are there 50oz. too? I dont want to put the wrong flywheel on the car...
Also, anyone have 1 flywheel bolt laying around? I have 5 of them. Gnomes stole my 6th one...
Old Jun 6, 2008 | 11:55 PM
4reboy's Avatar
4reboy
Default RE: Flyweigh weight....
i believe its 28oz, the same weight as the old 302's whatever that is. I remember because I think my dad got a 50oz by accident because it was for the newer 351's and the engine was shaking like crazy hahaha.
Old Jun 7, 2008 | 08:00 AM
67coupe's Avatar
67coupe
An older flywheel should be the 28 ounce. Since these engines are externaly balanced you need the take the crank, harmonic balancer and the new flywheel to a machine shopto be rebalanced to make the change.
Old Jun 7, 2008 | 03:07 PM
baddog671's Avatar
baddog671
ORIGINAL: 67coupe
I didnt say it IS 50oz, I was asking wether it is a 50 or 28. There is no way to tell apparently...
Old Jun 7, 2008 | 08:07 PM
MonsterB's Avatar
MonsterB
you can tell by how much it wieghs. i just went through this with my engine builder. it is really imortant to get the right one though. i have both. if you tell me how much it wieghs i will tell you which oine it is.
Old Jun 7, 2008 | 08:52 PM
tyler72's Avatar
tyler72
Different flywheels will weigh different amounts. It doesn't matter if they ar both Ford parts and both 28 OZ, on still may weigh more than the other but their balance weight could still be the same.
Old Jun 7, 2008 | 09:14 PM
mustanglover66's Avatar
mustanglover66
post a pic of the back side and I mit be able to tell you newer 302s did use them as well as older ones.
Old Jun 7, 2008 | 10:24 PM
67coupe's Avatar
67coupe
My point is that each flywheel is unique to each engine. You take one off one engine and put it on another youmay not be in perfect balance. If you have a speed /machine shop balance your crank you take the harmonic balancer and flywheel you are usingwith you.
fordfanboy
Nov 3, 2007 11:08 AM
dimebag
Nov 22, 2006 12:26 AM
