Compression ratio question.
Old Apr 29, 2005 | 05:43 AM
65_2plus2's Avatar
65_2plus2
Default RE: Compression ratio question.
I believe the big advantage to dished pistons is that you can push the compression a "little" higher while still maintaining a good valve clearance.
To make sure no one is confused about this, the dished piston will decrease compression and the domed (or as us older hot-rodders call them, "Pop-up pistons") will increase compression.
[sm=gears.gif]
Old Apr 29, 2005 | 04:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Do the domed produce more Hp than the flat tops? If so, why?
Old Apr 29, 2005 | 05:30 PM
67coupe's Avatar
67coupe
The tighter you sqeeze it before it lights the more violent the explosion. So more compression creates more power.
Old Apr 30, 2005 | 06:38 AM
Soaring's Avatar
Soaring
I ♥ Acer
OK, makes sense, but why do most hot rodders prefer the flat tops?
Old Apr 30, 2005 | 11:34 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Soaring
Could be for a couple of reasons. Piston to valve clearance maybe. Flat tops will generally have better quench that a dome.
Old Apr 30, 2005 | 01:24 PM
67coupe's Avatar
67coupe
The main reason flat tops are popular today is poor gas. Back when I started fooling with cars you could get good gas like SUNOCO 260. Back then pop tops were king and people were running 12.5:1 compression. Those high compression engines would go from idle to wide open and back to idle almost instantly. Those were the days. You can't run todays gas in one of those engines. 11:1 is about as much as you can get away with today.
Old Apr 30, 2005 | 02:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67coupe
Was the gas of yester year better because it contained lead? I thought lead was only added to protect the soft valve seats? If not, then how was gas back then better?
I also dug up a simple mathmatical formula to figure compression ratio. Simple algebra.
http://e30m3performance.com/myths/mo...comp_ratio.htm
Old Apr 30, 2005 | 05:12 PM
aamilo's Avatar
aamilo
Hey cool, that was the concept I posted earlier (now I have the algebra). I believe the difference in the fuel from yesteryear was the octane rating. If I recall correctly '60s fuel was around 120 for an octane rating where today it is usually under 97.
Old Apr 30, 2005 | 08:27 PM
67coupe's Avatar
67coupe
After all the smog equipment was added and compression ratios dropped in the mid 70's there was no need to make the higher octane fuel anymore. You can still by racing fuel at the track or speed shop, but it's about $4.00 a gallon.
Old May 1, 2005 | 07:38 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67coupe
I've see "Octane Booster" additive on the shelf at parts stores. Is that stuff any good, or is it snake oil?
