rear disk brakes
Old Jun 9, 2008 | 10:40 PM
vineman's Avatar
vineman
Default rear disk brakes
So, with the correct adaptors, can almost any ford rear disk brake setup be placed on a different rearend?
Old Jun 10, 2008 | 12:48 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: rear disk brakes
you want a cheap disc setup get a 92 and up "bubble" crown vic setup(preferably police) and all you need is to small shims and its a direct bolt on besides the lines and the shim
Old Jun 10, 2008 | 06:36 AM
vineman's Avatar
vineman
oh, well i guess i should have mentioned that I have an 8", i guess that might help. I was curious if disks on an 8.8" would fit the 8" or if I would just have to try and find out for myself.
Old Jun 10, 2008 | 09:14 AM
andrewmp6's Avatar
andrewmp6
Some say the ford explorer rear disc will work i don't know how true that is.Have you gave mustangsteve a look or http://www.ultrastang.com/Index.asp
Old Jun 10, 2008 | 10:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i think the explorer setup uses the big 9 inch bearing housing iirc
Old Jun 10, 2008 | 11:22 AM
kalli's Avatar
kalli
Hiya,
i got a 9" rear axle housing from quick performance racing. they make the housings themselves.
With those I got the Ford Racing rear dics that are very similar to explorer (some people say it's the same).
So from that I can't tell you if that will fit, but when rmodel says they're different and I can confirm I have em on a 9", then it's ?probably ? not an option. just a thought. i never had a 8", so I can't tell
Old Jun 10, 2008 | 06:19 PM
baddog671's Avatar
baddog671
Yes, Explorer discs are big bearing, and I belielve the Crown Vic's are too.
His brackets are expensive! 150$, I think not...
I am currently doing a MarkVII conversion which I hope to finish soon (if my freakin bearing retainers ever get here!). JamesW has a write up on his website.
Old Jun 10, 2008 | 11:27 PM
vineman's Avatar
vineman
the MarkVII is a Lincoln right? Does it have an 8.8" rearend? My 8.8" is from a Lincoln Continental.
Old Jun 10, 2008 | 11:52 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah the mark 7 is a lincoln
i really cool rear to find is a diesel mark 7 rear they had 3.73 and disc factory but the cars are rare
Old Jun 11, 2008 | 04:23 AM
Pony1968's Avatar
Pony1968
I have a setup from a crown vic with alumininum spacers and detailed instructions for the install. There is a guy on the classic Cougar site that sells the spacers or complete kits. You will need to trade the calipers in for rebuilt units. You can also contact Vintage Venom which is what I wound up doing as I decided to rebuild the whole rear. Thier kit is around $400. IIRC. Call me if your'e interested at 732 429 9203. Good luck, Dan Donlin
