No Power Steering!
Old Jun 11, 2008 | 06:35 PM
silverblue66's Avatar
silverblue66
Default No Power Steering!
I replaced my ps valve and cyllinder today and when I got is all bolted up I had no pwer steering. so I switched the two lines that come off the cyllinder and my wheel went all wonky and jerked back and forth. so I put them back and still no power. any ideas?
Old Jun 11, 2008 | 09:22 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: No Power Steering!
air in the lines?
have you turned it lock to lock with it running a few times
Old Jun 11, 2008 | 09:23 PM
flyingfool's Avatar
flyingfool
hmm, if you put them on backwards (which is why the wheel leans like it did,) i would assume that means the pump IS pumping but mabeye not enough? got all the fluid in? belt tight enough?
they are pretty simple. im just guessing here
Old Jun 11, 2008 | 09:42 PM
Mustang Dad's Avatar
Mustang Dad
I'd check with Stanger53. He is theguru on p/s systems. You can also check at http://www.stangerssite.com/.
Old Jun 16, 2008 | 01:53 PM
silverblue66
okay, I turned the wheels from lock to lock several times and nothing. is there a chance I damaged the valve by instaling the lines backwards or the pump?
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
