Spark Plugs?
Old Jun 15, 2008 | 04:54 PM
MonsterB's Avatar
MonsterB
Default Spark Plugs?
Okay the guy that assembled my engine recommended i use bosch platinum plugs. The johnny on the spot at AutoZone said that i should use a copper plug. he said that the platinum was too hot for older engines. WTF.
I am using the stock heads (with a lot of work done to them) and a complete MSD Ign. set up on my 289. wieand intake and holley 670cfm
I went ahead with Autolite Platinums. Nobody there could recommend a proper gap. i thinking about .0035.
What is the consensis on the Autolite plug and a good gaping.
Old Jun 15, 2008 | 05:03 PM
67mustang302's Avatar
67mustang302
Default RE: Spark Plugs?
Autolite coppers are good plugs. The platinums do tend to be too hot for performance on some domestic V8's, especially in an iron head, but I doubt your cylinder pressure is all that high, so it may not matter. As far as a gap, if you have electronic ignition with a CD box then you'll prolly want to gap in the .045-.055 range.
Old Jun 15, 2008 | 05:21 PM
racin66coupe's Avatar
racin66coupe
i would listen to your engine builder, not the monkeys at auto zoo
Old Jun 15, 2008 | 05:23 PM
MonsterB's Avatar
MonsterB
i should be running 9.5 to 1
Old Jun 15, 2008 | 07:19 PM
Starfury's Avatar
Starfury
With the MSD setup you should be fine running a .045" gap (stock was .035"). I don't think you'll have any problem with platinum plugs, as long as they're the proper heat range (AP45's). I've run them in my 331with 9.3:1 CR and they work just fine. The platinums will last longer than coppers, but don't expect any extra performance out of them.
Old Jun 15, 2008 | 07:26 PM
MonsterB's Avatar
MonsterB
Sweet. there gapped and in. now if i could just resolve my throwout bearing situation i can drop in the power plant. i dont know if i can use the staock t5 t bearing with a centerforce clutch
Old Jun 15, 2008 | 08:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I prefer to use copper resistor core autolite plugs.
Old Jun 15, 2008 | 08:46 PM
67mustang302
Copper resistor core Autolites are excellent plugs. If you go to the track a lot of the guys that are running quickly use them(among others). Platinums last longer, but the copper cores conduct heat and resist fouling better. Platinums are fine with the right heat range(true of any plug) in a mild application where you want the plugs to last, but the coppers are better for a performance application.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
firehorse02
Nov 16, 2015 11:28 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
