Did I score?
Old Jun 17, 2008 | 12:44 AM
valley firearms's Avatar
valley firearms
Default Did I score?
OK, I gotta brag. I picked this up today for $80. I had it tested and it works great.
I have never run a one wire alt. Do I unplug my regulator and leave it unplugged? Do I just run the wire from the alt to the battery side of the solenoid? Thanks for the help.
[align=left] [/align]
[IMG]local://upfiles/21693/444E8B386E4A46609C36995034F896A8.jpg[/IMG]
[IMG]local://upfiles/21693/15599812ABAE427682B19A0B7A357EA6.jpg[/IMG]
Old Jun 17, 2008 | 12:47 AM
4reboy's Avatar
4reboy
Default RE: Did I score?
dang thats nice, and yeah I think you unplug the regulator because the 1 wires are internally regulated or something, I can't be too sure though because I bought a normal 100 amp 3 wire
Old Jun 17, 2008 | 05:16 AM
musnicki's Avatar
musnicki
Yeah, I think that amp has an internal voltage regulator. I removed mine completely.
All you do isrun a single wirefrom the positive post on the solenoid to the alternator.
Old Jun 17, 2008 | 08:53 AM
tyler72's Avatar
tyler72
Yes. That alt is a delco remy, CHEVY style. You can remove your stock regulator because that alt has one built in. You just need tohook up the one wire directly to the battery or constantly hot side of thesolenoid. I cant believe you are cross breeding the stand! lol, j/k, looks nice.
Old Jun 17, 2008 | 11:46 AM
rst08tierney's Avatar
rst08tierney
Not bad if your going to put it in your Chevy. Dont even get that near your Stang, that would be wrong!!!!
Old Jun 17, 2008 | 03:06 PM
jlg2002's Avatar
jlg2002
you need to wire terminal 2 to 12 v also.
Old Jun 17, 2008 | 03:08 PM
tyler72's Avatar
tyler72
No you don't, not if its a true one wire alternator. They only need the one wire hooked up, hence why its called a one wire .
Old Jun 17, 2008 | 03:30 PM
jlg2002's Avatar
jlg2002
You could be right , Tyler. Most, if not every GM alternator I saw during my years as a ASE licensed auto tech (1975-85) had (in addition to the B+ wire) a top plug to supply voltage to the alt (which activates the internal Vreg) and transmit the idiot light signal to the dash for if the Alt was not charging.
So If its truly a 1 wire you're right! However, unless GM's changed their product, he will need a wire from the B+ to terminal 2 if that top plug is there.
Ps: if you want to see how much juice the alt can put out, you ground a tab located in one of the "D" shaped holes in the back of the alt frame (next to the regulator)
Old Jun 17, 2008 | 07:04 PM
valley firearms
[align=left]This is a Summit alt made for Fords. It is in a Ford housing. I need a 100+ amp alt. Soaring Jr, is that you?
ORIGINAL: rst08tierney
[/align]
Old Jun 17, 2008 | 07:12 PM
Aussie66Fastback's Avatar
Aussie66Fastback
[sm=bling.gif]very shiny
