What tool would I use?
Old Jun 17, 2008 | 07:12 PM
350kmileFord's Avatar
350kmileFord
Default What tool would I use?
Long story short, I got a rearend housing with a fine, but firm coating of internal sludge. I cleaned up the center section of the housing with some acetone and a wire brush. What tool would I use to clean the axle housings? I need some sort of rotary wire brush tool, most likely on a 3 foot long rod to get in there with (on a drill?). Anyone heard of such a tool? Links, suggestions appreciated.
Edit: Something similar to this, but with a longer rod.
http://www.sears.com/shc/s/p_10153_1...ol+Accessories
Old Jun 17, 2008 | 07:18 PM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: What tool would I use?
A steam cleaner works pretty good. You may want to soak in with GUNK first, it will loosen things up a bit.
Old Jun 17, 2008 | 09:40 PM
baddog671's Avatar
baddog671
I'd completely soak the thing in brake cleaner or some other harsh chemical and then take it to your local carwash around 1 in the morning. A few bucks and you could blast all that **** out of there...
Old Jun 17, 2008 | 10:22 PM
flyingfool's Avatar
flyingfool
evil, whats the$ average on the gunk stuff? when i had to clean my carb in that gallon of carb cleaner, it was almost $35! kinda suprised me
Old Jun 17, 2008 | 11:43 PM
Starfury's Avatar
Starfury
Can you get Castrol Super Clean where you live? It's banned here in CA (damnit!), but if you can get it, it's an awesomely toxic degreaser. Mixed 2:1 and left to soak for an hour, it should do the job just fine. Otherwise, large amounts of Chemtool (carb cleaner) will work. Engine degreaser (the Gunk stuff you're talking about) is basically diesel, which, despite current prices, is probably still cheaper for a gallon than the equivalent in Gunk cans. Works great, though
Old Jun 18, 2008 | 12:51 AM
Tony R's Avatar
Tony R
I like the product called greased lightning. I used to sneak it on base to clean out LAVs for inspections. It would take a few hours where before it would take a good week of scrubbing.
Old Jun 18, 2008 | 09:33 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
why not buy that tool youre looking at and weld a longer rod on it...
Old Jun 18, 2008 | 09:59 AM
groho's Avatar
groho
Home depot has extensions for drills, when your installing electrical in walls. Add a mild hone or wire wheel. Piece of cake. Or, spend $40 or so and hand it to a machine shop and have it hot tanked.
Old Jun 18, 2008 | 10:02 AM
kalli's Avatar
kalli
use a toilet brush and attach a broomstick to it ...
Old Jun 18, 2008 | 10:14 AM
andrewmp6's Avatar
andrewmp6
Theres a degreaser we use at work called sf 77 that stuff will clean anything i put it on.
