Question about Engine Sizes
Old Jun 18, 2008 | 04:08 PM
PshychosisStang's Avatar
PshychosisStang
Default Question about Engine Sizes
I am building a 1972 Mach 1 back to specifications of my father. If I remembered correctly he had always told me that he had the 351W, but everything I've read has said that the only the 351C was offered that year. Is this correct and I just am wrong on what I thought he had??
Also I have seen a lot of remanufactured engines sites, and found one that I like giving a 351W with about 365 HP. Question is what all would be different in putting in a Windsor if the car originally came with the Cleveland?
Thanks
Old Jun 18, 2008 | 04:17 PM
109jb's Avatar
109jb
Default RE: Question about Engine Sizes
Count the valve cover bolts. The Cleveland will have 8 bolts and the Windsor will have 6.
Old Jun 18, 2008 | 05:11 PM
racin66coupe's Avatar
racin66coupe
also, the waterneck will be directly into the block if its a cleveland, not in th eintake like a windsor
Old Jun 18, 2008 | 05:28 PM
pigcop's Avatar
pigcop
You are correct in the fact that all 351's that year were Clevelands (2V and 4V HO,CJ). The Windsor was not an option, but the 302 was.
As for what is involved in changing. Someone else here would have to tell you as I have never done that swap.
Diode Dynamics
28
May 26, 2022 12:02 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
