8" Axle Seal
Old Sep 27, 2008 | 07:21 PM
350kmileFord's Avatar
350kmileFord
Which direction do I put the seal in?
Would I install it so that the cupped portion is facing the dif? Or would I install it so as the metal backing of the seal is facing the differential?
http://i28.tinypic.com/ouwhs4.jpg
http://i32.tinypic.com/25jdxrt.jpg
Old Sep 30, 2008 | 03:18 AM
350kmileFord
Answers appreciated, hopefully this will be my last question on the subject.
Old Sep 30, 2008 | 08:32 AM
gjz30075's Avatar
gjz30075
Cupped side facing the diff.
Smear a thin amount of RTV on the outside circumference of the seal, ie, the surface that will mate with the axle tube. Use a proper driver to get it in perfectly straight. A large socket usually does the trick nicely.
Old Sep 30, 2008 | 09:54 AM
groho's Avatar
groho
Once you have the seal in place and seated, be sure to visually check and make sure the retaining spring is still in place on the inside of the seal. use a small hand-held mirror. Two items you need to be careful for here, first, make sure the spring does not come out as you put the axle in. Keep the axle centered as you install it. And don't forget to put a small amount of lube on the seal to keep from burning or tearing it under initial break in.
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
KingRando
Oct 2, 2015 08:06 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sep 24, 2015 09:18 PM
