Trans Oil Help
Old Jun 19, 2008 | 01:25 PM
drm_stang's Avatar
drm_stang
Default Trans Oil Help
Too all the Transmission Guru's, i am about ready to put my trans back in and wanted to ask a few i'm sure common questions.
First off:
What type of oil should i put back in my torque converter, is there a anti-slip additive needed?
Secondly:
Same as above, what type of oil should i put in the trans for longevity and is there an additive needed as well.
Thanks in advanced
Rob
Old Jun 19, 2008 | 01:34 PM
boogerschnot's Avatar
boogerschnot
Default RE: Trans Oil Help
Type F Auto fluid.. thats it as far as I know. Just put as much as you can in the converter and then top her off after its all together. Just make sure you dont over fill.
Old Jun 19, 2008 | 02:51 PM
69thunder's Avatar
69thunder
Be carefull not to many rebuilt transmissions use type f anymore. If it is stock then yes type f but if not probably dexron3 mercon or something similar. That is what mine has now.
Old Jun 19, 2008 | 03:16 PM
boogerschnot
hmm... never thought of that.
Old Jun 19, 2008 | 08:44 PM
drm_stang's Avatar
drm_stang
Thanks for the feed back, tranny is stock so i figure either one of the above oil suggestions will work out fine.
Cheers
Old Jun 25, 2008 | 10:48 PM
drm_stang's Avatar
drm_stang
Another quick question, how much oil am i putting in the torque converter. Fill it half full, lay it right side up and if the fluid start to trickle out then that is enough?
Cheers
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
