68 289 what 2 do look at pics
Old Jun 19, 2008 | 10:26 PM
quantumaxis's Avatar
quantumaxis
Default 68 289 what 2 do look at pics
This is my 68 i want to give it a morehorse power what should i do i just changed the air filter from a low profile to a high profile air filter but i need some help on what to do.
[IMG]local://upfiles/99446/3A26346457214F0EB0D1844A26D3F06D.jpg[/IMG]
[IMG]local://upfiles/99446/0DC345CD95D84F4BA74D8EFDA8F90CF3.jpg[/IMG]
[IMG]local://upfiles/99446/C1A25AEAA5574A04B5634629CB7B47C0.jpg[/IMG]
Old Jun 19, 2008 | 10:43 PM
Starfury's Avatar
Starfury
Default RE: 68 289 what 2 do look at pics
First off, you should look at either installing a filtered breather cap on the d-side valve cover to replace the little elbow deal, or simply install the proper elbow into the bottom of the air cleaner and run an oil-rated hose between the two. No good sucking dirty crap into your crankcase
Old Jun 19, 2008 | 10:57 PM
racin66coupe's Avatar
racin66coupe
do you want more horse power? an air cleaner isnt gunna do much. intake like the edelbrock rpm would be good on a stocker, a cam (not sure what type) a tune. headers, dual exhaust, etc
Old Jun 20, 2008 | 06:26 AM
tyler72's Avatar
tyler72
If you want power, order a set of long tube headers form Jegs. Also get an intake like stated above. A perfromer RPM, or RPM airgap would work nice. Call Comp Cams and they can recommend you a cam that will work with your stock heads. You should notice a big improvement.
Old Jun 20, 2008 | 09:53 AM
flyingfool's Avatar
flyingfool
could look into a pertronix electric ignition as well. doesnt add much, but gives a much nicer ride and gas milage and its fairly cheap. about $50
Old Jun 20, 2008 | 12:31 PM
MonsterB's Avatar
MonsterB
maybe a 408 stroker w/ a 100 shot of no2. oh, and a supercharger. thats where i would start.
you can also replace the blinker fluid and get a high performance muffler bearing
uberstang1
Dec 7, 2017 07:10 AM
9550
Oct 26, 2015 05:01 PM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
