rusted rear brake lines
so i dropped my diff. and cleaned it up and i need to replace my rear brakelines but it can get them to brake loose from the drums... any advice or products that you guys use to eat threw rust.. if i use any more force the nut is going to strip...
You can always try to apply heat (via torch), but be sure you've got a place for the heated brake fluid to go. They will (and do) tend to explode. Literally.
My recommendation is to simply take a pair of vice grips to the nut. The steel tubing will twist and eventually brake off, since it is rusted solid to the nut. You should replace everything anyway. (Sounds like you already plan to.) If not replacing the tubing, just cut a small section of tubing, re-flare and replace with a joiner.
The rusting of the nut is common... Good luck.
Try ansdsoak it in PB Blaster, that stuff works great. Most likely you will demolish the nuts around your brake lines but you will want to use new ones anyway. Usually, new brake lines come with the fittings already on the lines ready to go.
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
