Resistor Wire..??
Old Jun 27, 2008 | 05:04 PM
dugan's Avatar
dugan
Default Resistor Wire..??
Bump
reason for bump:
new subject, question.
Just read paper that came with my Flamethrower 40,000 volt coil, 1.5 ohm. it says that if you have a resistor in the wire that runs from the coil to igniton you have to remove it for the coil to work because it needs 12v to run.
well that doesn't make sense to me because it had a flamethrower coil on it when i bought it (same voltage and ohm) and it ran fine. so why now will it not work?
and finally HOW DO I REMOVE THE RESISTOR, WHERE IS IT? There is nothing in the engine compartment, would it be up under the dash?
Old Jun 27, 2008 | 05:24 PM
UH60LCHIEF's Avatar
UH60LCHIEF
Default RE: So I'm pissed.
So let me get this straight... It turns over, (strongly or it might be the batterybecause it's been a month), you are getting fuel, and there's no spark? (Verified?) It sounds like it's time to do some good old spark chasin'. Break out your multi meter and isolate the circuits that might have a short i.e coil etc. A good place to start is always your grounds, clean 'em up, but other than that make sure your components are getting juice and when you figure out which one isn't things get a lot easier. Good luck with it.
Old Jun 27, 2008 | 05:39 PM
Gun Jam's Avatar
Gun Jam
what does the pertronix ignition come with just a box like the msd box?
Did you add a new coil as well? are you getting 12v to the coil?
-Gun
Old Jun 27, 2008 | 05:41 PM
WD0AFQ's Avatar
WD0AFQ
Just to be sure, stick the points back in. Won't take long to eliminate that.
Dan
Old Jun 27, 2008 | 05:44 PM
dugan's Avatar
dugan
this is gonna sound stupid but i don't know how to set points or anything else...ever since i got the car it has had electronic ignition in it
tomorrow i will go out and start tracing wires/testing them and hopefully i can find an answer..
Old Jun 27, 2008 | 05:57 PM
davesanborn's Avatar
davesanborn
Pull your distributor cap off and double check to see if your new pertronix is installed/adjusted/working correctly.
Power to the coil?
Dave
Old Jun 27, 2008 | 06:51 PM
dugan's Avatar
dugan
ORIGINAL: davesanborn
Power to the coil?
Dave
ok stupid question, but im not to good with electrical/ignition type stuff.
What do you mean by power to the coil? should the coil be hooked up to anything like battery, or starter relay?
right now there is 1 black wire on the - side that goes into the distributor, and 2 on the + side one runs into the distributor, and the other goes into a clump of wires that runs into the firewall. I am assuming it goes to the ignition switch?
Old Jun 27, 2008 | 06:52 PM
dugan's Avatar
dugan
The coil doesn't have spark.
Old Jun 27, 2008 | 07:21 PM
davesanborn
Do you have a Voltmeter or a simple test light?
Dave
Old Jun 27, 2008 | 07:31 PM
dugan's Avatar
dugan
Yea but I can't seem to find it..go figure when I need something it is no where to be seen. I will most likely pick up one tomorrow.
do you think it could just be a faulty coil?
