Resistor Wire..??
Old Jun 30, 2008 | 11:48 AM
  #31
109jb's Avatar
109jb
Default RE: so I'm pissed
ORIGINAL: AV8ForFun
ORIGINAL: 109jb
Here is how you can test the coil.
1. First unhook everything from the coil to start from ground zero.
2. hook +12V to the coil "+" terminal
3. Put high tension lead in coil and secure other end to provide a spark gap somewhere to ground
4. run wire from a good ground to coil but don't connect to coil yet
5. now touch the wire from step 4 to coil "-" terminal
6. when you remove the wire from the "-" terminal you should get a spark from the high tension lead
You forgot step 7.
pick yourself off the floor when the fuel vapor explodes because the whole engine compartment is flooded fromcontinuously cranking without spark....J/K
Did you even read what I wrote??? where in there does it say anything about cranking??? You don't have to crank the engine to get spark out of a coil.
Old Jun 30, 2008 | 11:56 AM
  #32
AV8ForFun's Avatar
AV8ForFun
Dude, it was meant to be a joke.
And for those that didn't get it....I was implying that he had been cranking on the engine without success prior to starting your suggested procedure. I truly was not suggesting that there was anything wrong with your suggestion.
Man, what is wrong with everybody the last couple of months?....really been uptight on here.
Old Jul 3, 2008 | 12:38 AM
  #33
Builder1's Avatar
Builder1
Default RE: so I'
Does it run yet?
Diode Dynamics
28
May 26, 2022 12:02 PM
cbird1177711
Sep 3, 2015 08:43 PM
HIS S-197
Aug 10, 2015 05:47 PM
Sparkplugs.com
16
Nov 7, 2007 01:32 PM
Dark_Horse
Dec 18, 2005 05:40 AM
