Will trans hold
Old Jul 1, 2008 | 05:59 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Will trans hold
Ok well I got the ok from my dad to look for a V8 for the mustang. So far I have found 3 302s, 1 289, and 1 I6 300. How long will my 7.5 rear and my 3 speed tranny last with any of those engines?
Old Jul 1, 2008 | 06:26 PM
baddog671's Avatar
baddog671
Default RE: Will trans hold
The i6 200 was equipped with the 7.5" sp no problems there, but I'd take this time to upgrade to a v8 if your swapping engines anyways. For the 289's and 302's, they would probably hold up if your drove very calmly, but I wouldn't trust it for too long.
I'd consider upgrading your rear to an 8"
Old Jul 1, 2008 | 06:39 PM
cprstreetmachines's Avatar
cprstreetmachines
I did some crazy stuff to a 7.5 when I was 17, never went. Seemed to be stronger than the 8.Haha
Driving technique will determine that though. The younger you are, the less time you have before it explodes.
Old Jul 1, 2008 | 10:41 PM
flyingfool's Avatar
flyingfool
^ basicly thats waht it comes down to. if you dont dump clutches and rev it through the roof, it could last quite a while...and if it breaks, hey, great excuse to go look for an 8 or 9 inch!
Old Jul 1, 2008 | 10:45 PM
JMD's Avatar
JMD
Talk with Kalli, he has experience with some of these parts lasting behind a v8, and some of these parts not lasting behind a v8.....
Old Jul 2, 2008 | 08:46 AM
crunchyskippy's Avatar
crunchyskippy
I drove a couple years with a crate 302 on my 7.5 inch differential and did not have any problems. The last 6 months I *tried* to break it without any success. TheV8 engine Ihave was spec'd for ~300 ft lbs of torque (280 hp). I've never dyno'd it to confirm, though.
Basically, I found that with an open diff - I couldn't get enough traction to break anything. Also, I have a C4 (which helps relieve drive line stress).
If yours is in good shape, I wouldn't be too concerned. Good luck.
Old Jul 2, 2008 | 08:49 AM
67BullittCoupe's Avatar
67BullittCoupe
junkyard. 8.8 galores. you can find them with disc brakes and limited slip for 100 bucks.
personal opinioin.
Old Jul 2, 2008 | 09:28 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
I believe with an I6 300 you're going to have hood clearance issues anyway
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
