question on brake conversation
I own a 66 coupe I keep hearing about these Granada disc brakes. Can anyone tell me what year I would need. Also what year power brake booster? Lastly the brake rod that goes into the back of the booster whick one do I use. Thanks so much.....
Check out the Granada swap on my webpage too. This is a bit of an outdated swap, as there are other choices to put disc brakes on a 66 that are better and less expensive.
We have a '65 coupe and used 1980 Granada brake set-up. You can use any of the 75 to 80 Granada front disc brake set-ups for the swap over. You will need the spindles, disc's, calipers, and dust shields. You'll need to replace the original Mustang outer tie-rods with ones from a Granada of the same year. Your going to also need a dual chamber master cylinder and either a proportioing valve or combo valve and of course a few new brake lines. The change out is fairly easy and shouldnt take more than a weekend to make. Good luck, its the best upgrade you'll ever make.
OMGZZZZZZZ
I just did my Granada swap yesterday. (Happy 4th, right?)
check out my thread on it. Might answer some of your questions.
mungodrums
Suspension
Sep 7, 2015 07:22 PM
