New motor running but has issues
I know it is difficult to diagnose a problem via computer but here goes. New crate motor (347) with Pertronix ignition and Holley 650 carb. etc (all new stuff). It cranked right up and ran OK. After getting some other issues taken care of (alignment, brakes, shifter etc) I notice the motorwasrunning rough. When you give it gas and even some at idle, it misses at sputters and will even backfire a little. I thought it was a vacuum leak but cannot find one. I then tried adjusting the timing. When the motor came it was about 10 deg. BDC at idle and 32 deg. at about 3000 rpm. I moved the dist. some and it ran much better but now at idle its about 20 deg at idle and off the scale at 3000. Any ideas where to start. I have never had a Pertronix before so I did not know if there was any adjustment. The motor was run on a dyno and supposedly "adjusted". Thanks for helping us novices out.
Gary Ugarek
Sep 5, 2015 09:03 PM
adamfrosceno
Aug 27, 2015 07:40 AM
