seat belt bolt
Old Jul 12, 2008 | 02:49 PM
ky's Avatar
ky
America ftw
Default seat belt bolt
im trying to pull the seat belt bolts out to replace the carpet in my dads 66. i got the drivers sides out so then i go to the passesnger side and both of them are just stripped and spinning. now i can get the inner one out cause its in the driveshaft tunnel but i think im screwed on the outter one. cause its inside the rocker panel and theres no way to get in there.
what should i do? i beleive before the rocker gets welded up the factory welds a nut on the inside. so im assuming the welds broke and therefore the nut is spinning inside the rocker panel. now if i cut the bolt off, the side with the nut will fall down in the rocker and it would probably bounce around and make noise while driving [:@].
thoughts?
Old Jul 12, 2008 | 03:42 PM
ky's Avatar
ky
America ftw
Default RE: seat belt bolt
nvm.
impact drill ftw
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
