Rear Valence
Old Jul 13, 2008 | 06:01 PM
Shawnb23's Avatar
Shawnb23
Default Rear Valence
Does anybody know how to connect the rear valence on a 1966 ford mustang? Theirs 2 like L shaped pieces of metal at the bottom corners, but I have no idea what type of Bolt or screw would make it flush?
Old Jul 13, 2008 | 06:18 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Rear Valence
they go thru the quarters it has a stud that fits in it the lower quarter and uses screws along the top flange
there you the missing studs
Old Jul 13, 2008 | 06:33 PM
Shawnb23's Avatar
Shawnb23
No idea how it would go through the quater panel...
Old Jul 13, 2008 | 06:39 PM
Shawnb23's Avatar
Shawnb23
Their is what I'm trying to figure out how to connect, since you can't screw it down?
Old Jul 13, 2008 | 10:28 PM
HGC's Avatar
HGC
This should help. I have the valance off my 65 right right now. One photo shows the back of the quarter and hole the valance mounts to. I have that part painted black right now so I lightened the photo a lot to make the hole show up. Another picture shows how the special bolt goes through the bracket. The third pictureshows the mounting bolts I got from NPD in the rear valance mounting kit. The bolt goes thorugh the bracket and then into the inside of the rear quarter. The washer and nut go on the inside of the quarter. They are not great pictures as I took them pretty quickly tonight for you. If you need better just let me know.
[IMG]local://upfiles/82474/BED77248798A4F61BF4736A8D0168D97.jpg[/IMG]
[IMG]local://upfiles/82474/532088940D0D446FA1A42009A89344AC.jpg[/IMG]
[IMG]local://upfiles/82474/A115EF7498924202AF36D82756484D88.jpg[/IMG]
Old Jul 13, 2008 | 10:34 PM
Shawnb23's Avatar
Shawnb23
Wow thanks alot that's exactly what I needed to know. That hole wasn't their.. not sure why not? Maybe quarters have been replaced? doubt it though.
Old Jul 13, 2008 | 10:39 PM
HGC's Avatar
HGC
Do you need some measurements for the hole?
Old Jul 13, 2008 | 10:41 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
or someone wiped filler over the holes
Old Jul 13, 2008 | 10:42 PM
Shawnb23's Avatar
Shawnb23
That would be great. Thanks. Also how far up is it from where the quarter gos to a point on the bottom?
Old Jul 13, 2008 | 10:45 PM
HGC's Avatar
HGC
I'll take some pictures tomorrow evening with a tape measure on it. I'll show you the placement from the bottom and the side and the size of the hole. I won't be able to do it until about 8 or 9 PM central time.
