Bent Slave Cylinder
Old Jul 15, 2008 | 10:15 PM
jakstang's Avatar
jakstang
Default Bent Slave Cylinder
ok here's the problem...I am currently in the middle of getting my stang back on the road. While working under the car I noticed my power steering slave cylinder rod was bent (tip of the rod that passes through the drop bracket). I have a 65 mustang, 289 w/ Hooker long tubes. I do have the power steering drop bracket (welded on) with what were fairly new bushings holding the cylinder on. I've heard that the drop bracket does ruin the geometry of the slave cylinder so would this cause the rod to unseat the bushings and consquently bend my rod. I did notice that the inside bushing was toast. I was just curious if anyone else has had this problem and/or knows how I may fix it. Regards
Old Jul 16, 2008 | 11:29 AM
cprstreetmachines's Avatar
cprstreetmachines
Default RE: Bent Slave Cylinder
If it's only bent at the bracket, or after, don't worry about it. Just make sure it travel in and out od the ram smoothly, and that's not bent.
Old Jul 16, 2008 | 01:08 PM
sixtysix's Avatar
sixtysix
my rod broke off and my bracket came undone from rail-had to get new parts and weld a new bracket on....keep driving it until it breaks scott
Old Jul 16, 2008 | 03:35 PM
jakstang's Avatar
jakstang
Thanks guys, just checking I might end up just buying a new slave cylinder just to be safe, and hopefuly figue out some way to lock the rod on to the bracket a little better...
Old Jul 16, 2008 | 06:28 PM
boogerschnot's Avatar
boogerschnot
ORIGINAL: cprstreetmachines
I agree here.. Just as long as the rod is not bent and going into the cylinder you are good. Any leaks at the seals?
Old Jul 16, 2008 | 07:04 PM
jakstang's Avatar
jakstang
nope no leaks, the only part of the rod that is bent is the tip, so maybe I'll try straightening it as best I can and put it back together. I was thinking that the inside bushing somehow came loose causing the rod to shift and bend, any ideas on how to prevent this, maybe different type of bushings (It is going to need new bushings anyways now)...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
