randomonium in the engine
Old May 8, 2005 | 06:49 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: randomonium in the engine
If you look below the elbow, there is a rubber grommet. That pulls right out, and has the PCV valve attached to it.
Old May 9, 2005 | 12:18 AM
  #22
BillyBobJoe's Avatar
BillyBobJoe
now, according to some of the research i've done, only a few minutes but still,that should be the PCV valve. tomorrow i'll pull it off and tell you all what's there.
Old May 9, 2005 | 09:02 AM
  #23
67coupe's Avatar
67coupe
Pic #1 is not a PCV valve. The PCV is in the oil filler cap. The hose connection in pic#1 is much to large for a PCV.
Old May 9, 2005 | 11:05 AM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
You may be forgetting that there is more than one size of PCV valve. This does appear to be the bigger one, and yes that is a hose coming off it, not plastic. Every time you buy a new PCV valve, you get a new rubber "L" with it. Let's wait to see what he finds when he goes to look at it. If the PCV is in the oil filler cap, I will stand corrected. Fair enough?
Old May 9, 2005 | 11:38 AM
  #25
67coupe's Avatar
67coupe
This is the photo that 69FEcoupe was talking about
[IMG][/IMG]
[IMG]local://upfiles/6802/5CC260D84E51488C971D7E69EA44A815.jpg[/IMG]
[IMG]local://upfiles/6802/18C381DBDD944FEA8E203D6B78D576FB.jpg[/IMG]
[IMG]local://upfiles/6802/E319DD45CC9A4604A18009675D9B8D5E.jpg[/IMG]
Old May 9, 2005 | 11:39 AM
  #26
67coupe's Avatar
67coupe
How do post the image larger? All I get is thumbnails.
Old May 9, 2005 | 12:23 PM
  #27
Soaring's Avatar
Soaring
I ♥ Acer
You double click on the image to blow it up.....and, yes that engine does appear to have something sticking out of the oil cap that resembles a PCV. So, I guess I need to buy cyber beers for the forum.
I stand corrected.
Old May 9, 2005 | 12:28 PM
  #28
Soaring's Avatar
Soaring
I ♥ Acer
Now that we got that settled, what is the hose sticking out of the rear passenger side for.
Old May 9, 2005 | 12:49 PM
  #29
67coupe's Avatar
67coupe
Thanks for the help.
The one on the passengers side connects to a small fliter that is in the side of the air filter housing. I don't think that was the original set up for that year mustang, but it's been a long time. It looks more like a 74-79 set up.
Oh, make mine bourbon on the rocks please. JD or Makers Mark will do.
Old May 9, 2005 | 02:27 PM
  #30
Soaring's Avatar
Soaring
I ♥ Acer
Maybe that is why I was thinking 65-73 and it indeed is for later years. It's a strange set-up for sure. OK I have Maker's Mark, VO, Johnny Walker and some Tequila gold. What' your druthers?
