Oooo, Dat Smell
Old Jul 17, 2008 | 08:45 PM
DCStang65's Avatar
DCStang65
Default Oooo, Dat Smell
Just got my '65 Coupe back from the mechanic. New carb, air pan, tuning...
Driving it home, the wonderful smell of exhaust filled the car. I am still trying to get over the buzz (or get oxygen back to my carbon monoxide ridden cells).
So, for you die hards who have had 'Stangs, is this something I should get used to? I know that air was being pulled in through the vents, but believe I got them closed. Windows were open, but it still stank it up.
Had the exhaust done last year.
Thoughts anyone?
Old Jul 17, 2008 | 09:18 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Oooo, Dat Smell
are you missing your cowl to hood seal?
Old Jul 17, 2008 | 09:32 PM
DCStang65's Avatar
DCStang65
I will have to check, so not sure. Would the ventilation system pull anything into the car cab?
Old Jul 17, 2008 | 09:54 PM
Shawnb23's Avatar
Shawnb23
Does your exhaust exit past the rear valence? If not it could be coming from the trunk or underside of the car.
Old Jul 17, 2008 | 10:03 PM
ky's Avatar
ky
America ftw
part of the awesomeness of an old car
exhaust fumes = roses to men
Old Jul 17, 2008 | 10:25 PM
DCStang65's Avatar
DCStang65
Now that you mention it, the pipes may extend as far as the edge of the back bumper...which means I have to extend the pipes. Ugh...
Old Jul 17, 2008 | 10:34 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Make sure the exhaust is sound from front to rear. Listen for the tick, tick, tick, leak of an exhaust manifold gasket. Check for the fap, fap, fap, leak of a doughnut gasket. Put your foot over the tip and listen for phfit, phfit, phfit leaks from the pipes. If it's sound, look for blow by coming from the valve cover breather. Then move to the rear...Are there holes in the trunk? Are the pipes too short?
Sorry, but there is no excuse for a stinky car. Does not impress the chicks.
Old Jul 17, 2008 | 10:37 PM
4reboy's Avatar
4reboy
Yeah I would check for exhaust leaks and your seals
Old Jul 18, 2008 | 12:19 AM
65Coupester's Avatar
65Coupester
Absolutely not!
Make sure the PCV valve is working. Check the firewall for holes.
As everyone said, listen for leaks in the exhaust system.
The exhaust doesn't necessarily have to dump past the valence but it should be near there. If it turns down anywhere near the bumper , and you smell exhaust, then you most likley have a leak, further foreward.
Old Jul 18, 2008 | 10:07 AM
boogerschnot's Avatar
boogerschnot
With a new carb, you may just need to tune it a little better. My car did not stink before I changed out my brake booster. The booster had a vacuum leak so I was sucking more air, and I tuned it with a vacuum guage when I had the leak. There was no smell until I fixed the booster. Now there is no vac leak, but Im running rich so It smells up the car pretty bad.. Just check for vac leaks and then tune with a vacuum guage and that should get rid of most of your smelly problems.. Seriously!
