Which Radiator and fan for 400HP
Old Jul 17, 2008 | 09:13 PM
Bumblebee 66's Avatar
Bumblebee 66
Default Which Radiator and fan for 400HP
I am installing a 410HP Roush into a 1966 mustang and if at all possible I'd like to use the current dimensions for the radiator when purchasing a replacement for the old 2 core I'm taking out. It looks like an Aluminium 2 core (1 inch each tube) may do the job, and then I'll need a serious 16" fan.
Does anyone have any recommendations and experience on which would be the best quality and best result?
Cheers Bee
Old Jul 17, 2008 | 09:59 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Which Radiator and fan for 400HP
theres lots of options if you dont mind changing the dimensions. JamesW has a good write up on his which was pretty cheap. http://www.midnightdsigns.com/james/
if you want stock sized and appearance that limitschoices somewhat and increases the cost (but not necessarily the quality). try this as a starting point. http://www.jegs.com/p/JEGS/760077/10002/-1/10597scroll down to ford
IMO, 410hp (and depending on your location) would warrant going wider. Scott H has fitted a 67 radiator support panel. I am planning to cut outmy 66 panel to fit a wider rad. there is a natural line to follow there.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
Beerman309
Sep 19, 2015 01:16 AM
