[Easy] Please Help with starting
Old Jul 17, 2008 | 03:15 PM
MrMainEvent24's Avatar
MrMainEvent24
Default [Easy] Please Help with starting
Guys,
I have a 64 1/2 289 with 4 speed.
I left it sitting for a couple months and it wont start now. I tried jumping it - all the lights and radio will work but it wont turn over. I get a light clicking noise.
Also when I did this my regulator started smoking. Does this mean no power is getting to te solenoid?
All wires and everything are good.
What do you guys think I need to get this started?
Any help greatly appreciated!!!
Old Jul 17, 2008 | 03:20 PM
restomod66's Avatar
restomod66
Default RE: [Easy] Please Help with starting
Could be time for a new solenoid. How is the starter??? fairly new??
Old Jul 17, 2008 | 03:30 PM
MrMainEvent24
Not sure of the age of the starter. Bought the car about a year and a half ago, so its at least that old.
Old Jul 17, 2008 | 06:22 PM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
Sounds like a starter and a solenoid are both due, shouldnt be more than about $30 for both and both are extremely easy installs. I'd just replace em both if I were you, though if you ask WildMustang351 he'd tell you that's my advice because I'm filthy rich.
He, however, is a butthole, and I recommend you DON'T listen to him.
Old Jul 17, 2008 | 10:12 PM
Piraya33's Avatar
Piraya33
I just went through a similar problem. Take your battery to your local autoparts store and have them test the cranking amps. I had a red top optima battery and I thought all was good. I was wrong. My radio/gauges were all working fine, but when I turned the key all that would happen is some clicking noises. I replaced the battery with a yellow top that I had sitting in the garage and now there is no more problem. Good luck!
bjdutch2005
Mar 24, 2017 03:38 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
