Lights Suck
Old Jul 17, 2008 | 11:41 PM
DCStang65's Avatar
DCStang65
Default Lights Suck
Ever since I got my '65 Coupe, the blinkers and taillights have been dim to the point that people on the road around me lay on the horn because they don't think I am turning or stopping.
Had one person tell me to direct wire the headlights through relays. Any suggestions as to why the flashers and taillights are barely visible?
Old Jul 17, 2008 | 11:49 PM
ky's Avatar
ky
America ftw
Default RE: Lights Suck
old battery and the alternator is failing.
or your wiring is messed up and theres a weak wire.
Old Jul 18, 2008 | 12:07 AM
65Coupester's Avatar
65Coupester
The reflectors are possibly rusted or just not reflective. Paint them white.
The bulbs will blacken on the inside, replace the lamps.
The connections will corode. Steel wool the sockets. Check the wire connections, clean them up.
My tail lights brightened up alot when I painted the reflectors white.
Old Jul 18, 2008 | 01:10 AM
4reboy's Avatar
4reboy
I thought the reflectors were supposed to be like metal/silver? Mine are like a light silver, if we are talking about the inside of the housing where the bulb is
Old Jul 18, 2008 | 05:07 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ive got a set of www.mustangproject.com tail lights they are led now you wanna talk about bright they are awesome
Old Jul 18, 2008 | 07:44 AM
tyler72's Avatar
tyler72
Hve you checked the voltage while the car is running and the lights are on? It sounds to me like your voltage regulator may be going bad.
Old Jul 18, 2008 | 07:48 AM
rbrown22's Avatar
rbrown22
I would check the grounds for your lights also.
Old Jul 18, 2008 | 08:15 AM
ThanksDad's Avatar
ThanksDad
You have two problems. #1 the light is a single bulb that is not bright enough for todays standards. If you have the original lenses they are probaly cloudy. I don't think it's a wiring or alternator problem based on my results.
I replaced mine with a sequential/ LED set from Va Classic Mustang. They plug into the taillights socket and you replace the under dash flasher plug. About $125 and 1/2 hour. You have bright lights and the sequential is awesome. They also offer a non sequential. I shopped around, some kits require a lot of rewiring this kit was plug and go. Some kits had had a few LED's in the center this kit has LED's that cover the entire area. Also replace the lense's and bezels while you are at it.
You didn't ask but another thing I did was to repalce my under hood voltage regulator with a $15.00 electronic unit. It stopped the flickering headlight problem I had. They say you can take the stock cover off the old regulator and put it on the new one if you want the concours look.
lincolnshibuya
Dec 8, 2015 04:37 PM
bradleyb
Nov 27, 2015 07:50 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
