Turbonator?
Old May 7, 2005 | 01:14 PM
6mustang6's Avatar
6mustang6
Default Turbonator?
Has anybody tried the Turbonator? Does it even work? The link is at the bottom of the page.
https://www.turbonator.com/
Old May 7, 2005 | 02:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Turbonator?
Will it fit on a carbureted Mustang? For only $69.95 and a 30 day money back guarantee, I guess it wouldn't hurt to try it. But, I wouldn't get one. If you want turbo power, put on a real turbo. [:-]
Old May 7, 2005 | 05:28 PM
DSMtuner's Avatar
DSMtuner
Pay no attention to those scams. I know people who knew they were a scam, and bought it to prove once and for all that they are a waste of money. Funny thing is, it ended up actually causing a airflow restriction.
Wait.. I just realized that link is to those drop in steel stamps. Nevermind my comment then.
I hear they do have positive affects, but not 35 horsepower worth. And its definately not worth 65 bucks. Your paying for 2 dollars max worth of steel.
Old May 7, 2005 | 08:03 PM
Markstang1969's Avatar
Markstang1969
ORIGINAL: 6mustang6
I'm not sure I se the benefit of putting anything IN THE WAY of your intake, especialy anything that may break loose and go into your engine. Just my .02c
Old May 7, 2005 | 08:41 PM
67coupe's Avatar
67coupe
Causing a turbulance in the air fuel mixture would have the effect of seperating the heavier fuel from the air like a centrifuge. Not good.
In the 70's there were a lot of devices claiming fuel mileage improvements such as a propeller that mounted under the carb to swirl the air. There was a device that replaced your coil wire that had a gap the coil had to build up a hotter spark to jump. All these things in the directions said to install the device and advance the timing 2 degrees. If you advanced the timing and threw the device away you would get the same results as far as fuel mileage is concerned.
Chris D
Mar 2, 2008 09:01 PM
86bluethunder
4 Cylinder General Discussion
Dec 20, 2007 01:37 PM
Ontherocks98
Jan 2, 2005 07:17 PM
