New stuff = New problems
Old Jul 18, 2008 | 11:11 PM
Shawnb23's Avatar
Shawnb23
Default New stuff = New problems
Well I recently went to and got new tire's and rim's put on my 66 and driving home the steering wheel became pretty much useless to the left and everytime I hit a bump it went crazy. Got it home and have played with it for a few day's. Jacked it up and turned the wheel the wheel is tight, adjusted the screw on the top of the steering box to make it a bit tighter. Ok... seem's fine even when not moving. Once you gain any speed the wheel becomes loose to the left and crazy when you hit a bump. I didn't have it aligned at the time figuring it would be ok to drive around till I replace everything. Could this be caused by just the alignment? Ball joints and everything appear to be tight and I have jacked it up and their is no improper movement in the front suspenstion.
Old Jul 18, 2008 | 11:26 PM
Starfury's Avatar
Starfury
Default RE: New stuff = New problems
Sounds like something's loose. Control arm bushing, strut rod bushing, something's got to be loose. Take it to a shop and get it checked out ASAP. Many shops will do free suspension checks
Old Jul 18, 2008 | 11:31 PM
ky's Avatar
ky
America ftw
new rims and tires usually means you should get it aligned too. that way everything will get along and ride smooth together.
Old Jul 18, 2008 | 11:39 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
+1
Let us know if you made it to the shop in one piece.
Old Jul 25, 2008 | 05:32 PM
Shawnb23's Avatar
Shawnb23
Well I made it back to town and as I thought EVERYTHING was tight and in working order. Got it aligned, but the steering wheel still gos loose to the left when you get moving? I would think the steering box would show this freeplay when it's sittin still or up in the air if this was the problem?
Old Jul 25, 2008 | 06:22 PM
JamesW's Avatar
JamesW
what size wheels/tires & backspacing did you use?
Old Jul 25, 2008 | 07:24 PM
Starfury's Avatar
Starfury
Like I said, something is loose. No respectable alignment shop will align a car in that shape. Find yourself another shop and have it checked out.
Old Jul 26, 2008 | 12:19 AM
Shawnb23's Avatar
Shawnb23
I went with 17 x 8 rim's with 4.75 backspacing, wrapped in 245/45/17 tires. The shop that I had check everything out (because I couldn't find out what was wrong) rechecked everything and aligned it for free. We do alot of business with them and I personally wouldn't doubt what they do.
Old Nov 22, 2008 | 11:03 PM
paulschoch's Avatar
paulschoch
I just posted a simular problem, on my 65' I put on 225/55 16" wheels. I rebuilt the front end and 2 different alignment shops can't get the car to stop darting and wondering all over the road. I hope someone can help me.
Paul
Old Nov 22, 2008 | 11:05 PM
lunarweasel's Avatar
lunarweasel
Did you do the negative roll or shelby drop to correct the issue 65-66 cars have with larger wheels? Don't know much about it myself, but it is a known issue.
