1970 mustang, electrical problems.
Old Jul 21, 2008 | 02:29 PM
nwprblmdifrntshw's Avatar
nwprblmdifrntshw
Default 1970 mustang, electrical problems.
so i was on my way to a show the other day when i went across an intersection and all of a sudden my car died. EVERYTHING electrical is gone, now i can't find out whats wrong with it. i've checked the battery, load and all, it's good what else could it be? any thoughts anyone?
Old Jul 21, 2008 | 02:30 PM
Nabster's Avatar
Nabster
Default RE: 1970 mustang, electrical problems.
If everything just went at once, it could be the ground to the block. Follow the negative cable form the battery and make sure it's connected to the block.
Old Jul 21, 2008 | 03:16 PM
jlg2002's Avatar
jlg2002
So it just "up and died"? won't crank, lights won't come on, etc? Check the plug over by the master cylinder for tightness. Check the batt connections, check the battery. all the power goes into the car thru that plug.
Old Jul 21, 2008 | 04:19 PM
WildMustang351's Avatar
WildMustang351
One of the most common causes of electrical failures are bad grounds,Most people neglect these and think they are not important because they are so simple.
Battery to frame,frame to engine,engine to firewall,not in that oreder just make sure they are connected to those points. good luck
Philhampton1
Aug 21, 2015 12:04 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
daytooday
Aug 11, 2015 09:22 AM
89blueslug
Aug 10, 2015 07:20 AM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
