welding help
Old Jul 21, 2008 | 03:33 PM
groho's Avatar
groho
Default welding help
this is for those guys/gals, who've done body work & welding. When MIG welding, can you get as good a weld using innershield flux-core wire, as you can with solid wire and 75/25 gas mix? I'm picking up a miller 135 and need to determine if I can get by with flux-core, or need to spend extra on a tank/regulator.
Old Jul 21, 2008 | 04:31 PM
Gun Jam's Avatar
Gun Jam
Default RE: welding help
I have limited experience MIG welding but I have always had good luck with the shielded gas. I recommend shelling out the extra money and skipping the flux core.
-Gun
Old Jul 21, 2008 | 04:32 PM
67 evil eleanor's Avatar
67 evil eleanor
Money well spent.
Old Jul 21, 2008 | 04:35 PM
AV8ForFun's Avatar
AV8ForFun
+1. I've done both and the clean up on the flux core can be a problem. If you don't removeall the slagyou will have corrosion problems. I don't know for certain if there is any strength difference within the welds, but the using gas to shield the arc produces a much more "professional" looking weld. my .02.
BTW, I bought a new Miller 175 and it came with the regulator and hoses. I don't know if the 135 does or not.
Old Jul 21, 2008 | 05:50 PM
65rangoon's Avatar
65rangoon
ive dont both, having a shielding gas is the way to go. You can get a much better weld as well as have a lot more versatility as to material thickness. (it effects penetration)
Old Jul 21, 2008 | 07:15 PM
Adrenolin's Avatar
Adrenolin
Without a doubt go with the gas.
Old Jul 21, 2008 | 08:11 PM
MonsterB's Avatar
MonsterB
GAS IS WAY CLEANER.
Old Jul 22, 2008 | 01:01 AM
spdrcer34's Avatar
spdrcer34
..and another vote for Shielding Gas...I use C-25 for my sheetmetal welding. I did a couple complete jobs with Shielded Core wire, and it was HORRIBLE! Spatter everywhere...burn through.....
After the 2nd job took 2x longer than is should have, I went out and bought a tank....
Ryan
Old Jul 22, 2008 | 10:59 AM
ky's Avatar
ky
America ftw
do not get a welder that doesnt have a gas hookup. the welds suck and are ugly.
get the one with the argon hookup.
drfister
May 3, 2018 10:38 PM
cyclop5
Oct 3, 2015 09:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 17, 2015 07:57 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
