2v swap
Old Jul 24, 2008 | 08:40 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default 2v swap
Well my 67 had it's carb decide to die last week right after I rebuilt it. So it has pretty much sat in the driveway for almost a week now. I decided to go 2v since we couldn't find a 1v cheap enough to get. Ordered the 2v H/W and 2v adapter from Stovebolt. Got them yesterday. Fixed it all up and put it on today. Ran it for the first time since the carb breaking. Now we are fine tuning the carb. Almost had hood clearance problems. Just some pics of it. Now I just have to custom make my throttle rod to make the gas pedal work with the carb since it is a different style than the 1v carbs.
2v swap
2v H/W - 65
Adapter- 15
Electric Choke- 10
Old Jul 24, 2008 | 08:54 PM
ky's Avatar
ky
America ftw
Default RE: 2v swap
dont drop anything down that port
Old Aug 4, 2008 | 11:45 AM
sixpony66's Avatar
sixpony66
Default RE: 2v swap
Looks good, from what I've been told, without the spark control valve on the old 1100,your vac from the carb won't be right with a stock dizzy (no centrifugal advance) now would be a good time to switch to a duraspark,eliminate the points and have one less variable to worry about. What kinda breather are u usin?
Old Aug 4, 2008 | 11:50 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
Default RE: 2v swap
almost had hood clearance issues? withOUT an air cleaner?
Old Aug 4, 2008 | 11:59 AM
Waffles's Avatar
Waffles
Default RE: 2v swap
and looking through your photos i see a screenshot from MOH:AA LOL! I played MOH:AA, MOH:SH, and MOH:BT when they first came out.... YEARS ago. Have since played SOF2, BF1942, COD, COD:UO, COD2, COD4, and recently just downloaded Combat Arms (free DL, check it out)
Just kinda funny. Took me back YEARS with that screenshot. I was one of the first people to discover Landsharking... and I coined that phrase (by naming myself "Jaws The Landshark" and one of the first to get on the Church roof in The Hunt.
God I miss that game.
Old Aug 4, 2008 | 12:05 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: 2v swap
ORIGINAL: sixpony66
I cut my line to the spark advance and hooked it up to the new carb. I also have the pertronix ignitor setup. I can't fit a breather on the carb. I found out I have less than 1 1/2 inches of clearance left so I can't have one on. Also it requires a new throttle control on the carb, but the way I did it I made a cable throttle setup. If you use the Clifford 1v to 2v adapter you can put a breather on. It is shorter and it deletes the base plate.
Old Aug 4, 2008 | 12:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: 2v swap
ORIGINAL: Waffles
I have all. MOH: AA, SH, BT, and PA. I can't fit any more games on the laptop until I get an external hard drive.
Old Aug 4, 2008 | 12:10 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: 2v swap
Old Aug 4, 2008 | 03:20 PM
1965fastback's Avatar
1965fastback
Default RE: 2v swap
Nice setup, thinking of doing one but i got a 1v rebuilt by POny carbs for my b-day so i can't.
Old Aug 5, 2008 | 01:33 AM
sixpony66's Avatar
sixpony66
Default RE: 2v swap
Yeah, I don't know from experience, I'm still using the 1100 and stock dizzy but from what I've been told the spark control valve puts full manifold vacuum to the dizzy when it opens to compensate for not having centrifugal advance in the dizzy,whereas with your new carb all you have is venturi vacuum. I believe in 68 they went to centrifugal advance and did away with the spark control valve so you could probably use that dizzy and still keep your pertronix.
[/align]http://www.fordsix.com/forum/viewtopic.php?t=18841 I've also heard some people say they did a way with the coolant plate and got extra clearance, but I think that would put a lot more heat on the carb. You should be able to find some kind of low clearance breather, wouldn't want to run it without a filter!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
