Selling the HEI Dizzy
Old Jul 25, 2008 | 01:23 AM
photocliff's Avatar
photocliff
Default Selling the HEI Dizzy
I am selling my HEI never used distributor. It is the same oneI offerd dugan a few weeks back.
I never used it because my plans changed. 50,00 volts and accuracy up to 7,500 rpm's!
Thanks for looking,
photocliff
http://cgi.ebay.com/ebaymotors/SB-Fo...3286.m14.l1318
Old Jul 25, 2008 | 01:38 AM
Coolerguy1965's Avatar
Coolerguy1965
Default RE: Selling the HEI Dizzy
Ok for some reason it will not let me PM you about this so I'm just going to flat out ask it.
What is the difference in an HEI Distributor and just a regular one? I read on the internet that it has a mechanical vacuum advance...what is that? I read on your ebay page that it was for a 289/302 which is awesome because thats what I have. It is completely bone stock though is that going to make a difference? How easy is it to install this?
I feel like a gigantic Noob for asking all this but I simply do not know.
Old Jul 25, 2008 | 11:59 PM
photocliff's Avatar
photocliff
The HEI eliminates the points and condensor, which always needs adjusting.
The vacume advance is adjustable but i am not sure how it exactly works but you use a small allen wrench through the vacume hole to adjust it. I think you can regulate how much it advances by making the adjustment.
The HEI was the mainstay distributor for chevys in the late 70's- into the 80's but the gears and shaft lenght was modified to fit the Ford small block. There are other style of electronic ignitions out there but this is one of the least expensive for the bang.
If you are trying to keep its original look then there are other ways of converting your original dist into a pointless one.
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
mdg
Oct 1, 2015 07:04 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
UrS4
Sep 30, 2015 10:13 AM
