what goes here?
Old Jul 25, 2008 | 10:32 PM
ky's Avatar
ky
America ftw
Default RE: what goes here?
good idea. those small holes like that are what let exhaust fumes inside.
Old Jul 25, 2008 | 10:33 PM
65Coupester's Avatar
65Coupester
What diameter are the holes?
Could be for heater core. On the 65 the AC hoses were on the right side, don't know about the 68 but they look too small, if yours match the photos.
I pluged my holes with plastic hole plugs from Home Depot, painted black.
Old Jul 25, 2008 | 10:38 PM
jimmy428's Avatar
jimmy428
my heater core and ac lines are in place, plus they are too small for those. no biggie i'll just plug em. i'll go to home depot and try to find some.
just let me know if something pops up or if someone finds something out cause i can always pop out the plugs.
ky's Avatar
ky
America ftw
lol.
for like the 3rd time, its not the heater hose lines. you can see in the pic the heater hoses are already run through the correct holes.
Old Jul 25, 2008 | 11:06 PM
photocliff's Avatar
photocliff
I got it the first time true66gt. But then....some of usguys don't read it all
Old Jul 25, 2008 | 11:23 PM
ky's Avatar
ky
America ftw
i completely understand. dislexia and ADD dont help the problem either
Old Jul 26, 2008 | 05:29 AM
kalli's Avatar
kalli
i'll check on mine later maybe I have somethign stuck in there.
But for the moment I'd suggest that there were mounting points.
The lower for your brake line and the upper for the stuff you have a cable tie around ??
Old Jul 26, 2008 | 08:50 AM
dodgestang's Avatar
dodgestang
The heat hose lines used to have a strap that was bolted to the firewall. Most likely the strap was threaded in there in the hole above your brake line.
The hole below would be for the brake line clip that holds it to the firewall to keep it from bouncing around
Old Jul 26, 2008 | 08:56 AM
Starfury's Avatar
Starfury
I'd have to double check, but I believe my car has a snail clamp around the brake line in that lower hole there. Definitely a good thing to have to keep the brake line from rattling around.
Old Jul 26, 2008 | 12:25 PM
Stepman's Avatar
Stepman
I'll play. The lower one is for a brake line clamp. The top one looks like it's for a stud mounted to the heater box to support it. Maybe the stud broke off.
